I didn't know if there would be clearance issues between tractor and tire with the wider rims. I have a 400lp with the "correct" wheels and rims and 14.9 tires and a non-running 450lp with the same wheels and tires.
What I want to do is put duals and a heavy front blade on a tractor and use it to help clear some overgrown land. I also have a basket case 400lp that I would do this on as the sheet metal is junk and the motor is stuck and third gear is out in a bad way. I could resurrect the poor thing and build a heavy front end for it and use it instead of beating up the nicer machines.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
