Re: Farmall 450 Gas Brake issue
Posted by Janicholson on January 24, 2012 at 20:06:11 from (67.72.98.45):
In Reply to: Farmall 450 Gas Brake issue posted by Tony_Idaho on January 24, 2012 at 10:03:26:
WIth the brake adjuster loose (not pulling the small links inside) the space between the outer housing and the stack of disks and the expander should be less than .060" and more than .030" If it is more like .100+ it will not be happy scuffing or cleaning or springs will not make it stop well. To tighten it up, material must be removed from the housing where it meets the tractor by machining it off.
Measure the stack with a depth gauge on a caliper.
then measure the depth of the housing to the wear surface from the mount flange. Jim
