Posted by rustcollector on January 25, 2012 at 07:13:02 from (67.142.161.18):
In Reply to: Re: Cotton Pickers posted by Wardner on January 24, 2012 at 22:43:50:
Wardner,
The drop housings are gear drives. The chain drive housing on an MV is a thicker housing on the top. I have never checked the parts books enough to see if the axle housings are the same or different, but suspect that they are the same.
The brake pedals are connected directly with long rods with yokes on each end and an eyelet brazed onto the tractor pedals to give same amount of motion. The clutch pedal has a rod down to a shaft that runs across the frame on top of the transmission and a short lever then connected with a rod to the clutch pedal. Fairly simple and maintained engineering fundamentals even for that day.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
