Re: Belly pump hydraulic lines
Posted by LenND on January 26, 2012 at 13:05:20 from (74.207.160.118):
In Reply to: Belly pump hydraulic lines posted by Jim Paterson on January 25, 2012 at 18:35:58:
I have my return hose hooked into the top of the fill tube with a tee. Works good for what I use---cult and disk. It may not if you have a newer loader that needs more fluid. You may need another supply tank. I use two way cylinders with down pressure with this setup.
