504D fuel leak
Posted by dahlia21122 on January 26, 2012 at 13:23:48 from (68.48.10.207):
I have a Int'l 504D with a Roosa Master injection pump. It has a manual shut down cable. The fuel is leaking around the shaft that goes into the pump housing. When tractor is sitting in shed it drains the tank dry. Easy fix? O-ring? Any help would be great Thanks, Andy D.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
