Re: Farmall H cam
Posted by David Terry on January 26, 2012 at 15:18:47 from (24.151.201.3):
In Reply to: Farmall H cam posted by David Terry on January 26, 2012 at 04:55:33:
I didn't make myself clear. The H has a distributor not magneto. The two teeth with dots are about 20 teeth apart. One is a heavy dot, the other is a lighter mark. When the reference points are aligned, Should the number one piston be at top dead center, or coming up on the compression stroke?
