They can be tough and if rusted solid, damn hard to do with the bolster in place. Might want to hire a kid to crawl under the tractor.
First step is to compress the spring with one or two tie wraps. Remove the wire retaining clip. Try to rotate the the tin sleeve (on the right in picture). May need heat. When it is free, remove it to expose the 1/2" diameter pin. Remove pin. Remove angled hand crank shaft by removing cotter pin.
If the heavy sleeve is rusted solid, try heat. Bear in mind that some wayward heat may affect radiator. This is a good reason to remove the bolster.
It's been awhile since I have done this job but I think I have got the sequence right. Good luck.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
