If he is using the pump, or if it still has its guts, the ports are going to be closed. If it is not used, the control could be put in the "lower" position and kept there. But if he is using the Belly pump, It is best to route the oil into the top of the reservoir. with a T. If the belly pump is being used on a single acting cylinder, they probably need to be kept apart. The use of a metal add-on reservoir for the circulation of oil in the live pump would keep the heat down if plumbed into two ports. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
