Posted by Janicholson on January 26, 2012 at 18:49:44 from (67.72.98.45):
In Reply to: 650 Diesel smoking posted by plow hand on January 26, 2012 at 17:44:39:
Assuming you ran it for 10 to 15 minutes at least getting it at least warm, and assuming the pump is putting out enough fuel, and timing on diesel is correct, the situation might come down to analysis. A compression check on diesel will need a 0-600 psi gauge, and the adapter to those injector ports It will also not turn over well on diesel due to the design not intended to do so. Checking on the gas side is not important unless there is a stuck primary valve. If the compression relief valve system has one that is stuck open, the situation you describe will happen. Looking under the valve cover to assess the position of the starting valves can work, but if one is burnt, it might look OK but leak diesel compression into the start/spark chamber. If cracking the diesel injector lines lets you find the missing cylinder, change the injector with another cylinder to see if the miss follows the injector, if so the injector is the issue. After the compression check if you decide to do it, decisions can be made. Jim
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
