Re: International 330 Utility wiring diagram
Posted by Janicholson on January 26, 2012 at 18:58:27 from (67.72.98.45):
In Reply to: International 330 Utility wiring diagram posted by Bryton K. on January 26, 2012 at 16:11:46:
a single 12 gauge wire goes from the bright /dim terminal on the light switch to the front, then splits to each light (solder and shrink tube the splice). The rear light hooks to the terminal with no resistor, it is on in both D and B with full volts. 12 gauge is best there as well. All lights are grounded through the mounts. Some get rusty and many have run a ground wire from the housing parallel with the supply wire and grounded near the light on the tractor casting or suitable good ground. Jim
