Re: 484 Pto squeels when engaged
Posted by ihman73 on January 26, 2012 at 19:56:31 from (38.104.162.142):
In Reply to: 484 Pto squeels when engaged posted by 40204320bill on January 26, 2012 at 19:20:41:
Sounds like you have several issues to resolve. Start with the simplest things first: make sure cooler is getting adequate airflow, check oil flow to and through cooler, then after you have potential cooler issues dealt with the pto problem. Not sure about how the engagement works on that model, there could be a leak somewhere in that circuit. Does the pto work at all or does it stop when a load is applied? Does the noise only occur on engagement or does it persist?
