Re: sickle bar mower for a/sa fit c?
Posted by old on January 26, 2012 at 21:29:47 from (209.86.226.32):
In Reply to: sickle bar mower for a/sa fit c? posted by soundguy on January 26, 2012 at 18:11:25:
Wish I could help you on that one but since I only have an A with a 6 foot sickle mower I can not say if it will fit or not. Only thing I might be able to do to help would be to measure how wide the mounts are on the rear end of my BA and then you could compare that to your C and of close you might be able to make it work. I do know the draw bar had to be removed to install the mower I have
