Re: sickle bar mower for a/sa fit c?
Posted by gene bender on January 27, 2012 at 01:32:05 from (67.55.227.172):
In Reply to: sickle bar mower for a/sa fit c? posted by soundguy on January 26, 2012 at 18:11:25:
You will need some brackets as the drawbar from the A and B is different from the C So if youre talking bolt and unbolt no it wont but it would be easy to just make two pieces of iron fit the mower to the Cs drawbar all you need to do is park them side to side
