Posted by Janicholson on January 27, 2012 at 09:13:02 from (199.17.6.36):
In Reply to: Farmall H Help posted by mattlans on January 26, 2012 at 18:54:24:
If it goes into fifth early and seems to have a very short throw into fifth (it is shorter than all other gears from new) it could be a bent 4th 5th shifter fork. The pivot in the lever tower could be worn and allowing that issue as well. There is a shift repair kit someone mentioned about two weeks ago.
Today's Featured Article - New Hitches For Your Old Tractor - by Chris Pratt. For this article, we are going to make the irrational and unlikely assumption that you purchased an older tractor that is in tip top shape and needs no immediate repairs other than an oil change and a good bath. To the newcomer planning to restore the machine, this means you have everything you need for the moment (something to sit in the shop and just look at for awhile while you read the books). To the newcomer that wants to get out and use the machine for field work, you may have already hit a major roadblock. That is the dreaded "proprietary hitch". With the exception of the
... [Read Article]
Latest Ad:
[More Ads]
