Hi Bill, is the mower 540 RPM (large PTO shaft splines) or 1000 RPM (small PTO shaft splines)? Does you 484 have remote hydraulic outlets at the rear of tractor? If so pull the remote hydraulic lever with nothing connected to the outlets, this should make the hydraulic relief valve squeal in the MCV valve under your left foot rest. Is this the same sound you hear when PTO is engaged?
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
