The mounting "brackets" for the C21 resemble the U draw bar assembly for a C. It bolts over the rear axle tubes. (Very similar to U shaped draw bar on your H)The rest of the frame of the A or SA mower bolts to that bracket assembly, on one side a bolt goes thru both members and pivots and on the other side it's made to break-away.I have one that I can take a picture of that would make it much clearer than what I have described. To backtrack just a bit, this is for the rear mounted mower. Question, why a 5' vs a 6' cutter bar?
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
