Re: F-20 valves
Posted by Bill Krosnicki on January 27, 2012 at 19:56:36 from (50.33.226.67):
In Reply to: F-20 valves posted by Bob M on January 27, 2012 at 17:55:54:
I doubt that the valves are too long...
Which direction do you run out of adjustment? I wouldn't take the engine apart again. If the valves are too high you might try grinding a little off to get the right clearance. Another possibility could be if you used one of the newer style thinner head gaskets, it will affect valve adjustment. I compensated by placing washers (all the same thickness) under the rocker arm pedestals.
Also, there is a possibility you have dirt in the tappets that could be causing you to bottom out the adjusting bolts.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
