Re: F-20 valves
Posted by 36F30 on January 27, 2012 at 20:37:22 from (75.162.53.154):
In Reply to: F-20 valves posted by Adam Simcock on January 27, 2012 at 17:55:54:
Assuming you cleaned this engine and dirt is not the problem......
If the valves are too high or long meaning they protrude too much they are shot. Valve grinding takes material off the valve face in effect making them "longer" because they sit deeper in the seat. If they were ground down to the point they have no margin left, they need replaced. Add to this the grinding of the seats and the valves get even longer. Years of wear and quick valve grind jobs can be ground out but the geometry can be way off, leaving multiple valve protrusion heights. All head "rebuilds" are not the same, there is a big difference between a valve job and a rebuild.
The solution is new seat inserts and new valves together and everything will then be in the proper geometry.
This post was edited by 36F30 at 20:38:17 01/27/12.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
