Re: F-20 valves
Posted by robgIN on January 28, 2012 at 06:08:12 from (76.208.31.18):
In Reply to: F-20 valves posted by Adam Simcock on January 27, 2012 at 17:55:54:
are all the valves even across ? If not you either have seats ground way deep in the head or valves ground way too much undersize, or maybe some of both. Did you mill the head ? There is a lot of adjustment in those things, unless you have dirt and crud in the pushrod pocket in the lifter you shouldn't run out of adjustment unless you milled a lot off the head. If your valves and seats are causing that issue, you need new seats and probably valves, easy to get , I see 3 places listed that can help you.If your valves are sticking up that high you will have NO valve spring pressure to close them.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
