If you use any starting fluid it can shorten the life (or ruin instantly) the glow plug filament. Hard starting is often an indication of tired engine compression making diesel ignition difficult. When these (and Summer diesel fuel in the tank) can conspire to have you use the plugs longer than normal, and the plugs are like light bulb that have no bulb. the filament gets hot enough to glow, which begins to oxidize the wire like a burning out bulb. My first impression would be to check the fuel characteristics, then compression, Voltage can also be high if the system is shorting through the button, or a out of spec resistor is in place. Check easy things first. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
