Re: tire size on a 574
Posted by jimb2 on January 28, 2012 at 09:29:30 from (174.115.9.174):
In Reply to: Re: tire size on a 574 posted by Kevin Roberts on January 28, 2012 at 06:16:04:
Hi Kevin, is there any farm machinery salvage yards in your area. My brother got a pair of 13x28 rims from a wrecked combine.
Are you using the 574 for anything that ground speed is critical because if you put larger tires on the ground speed will increase. The 74 and successor series of tractors had at least 3 different transmission speeds, slow, med and high. The transmission speed installed can be determine by the serial number suffix letters xxxxBS is fast gear box with 20 MPH gear set.
JimB
