It is normal to have to use glow plugs even when warm unless you just shut it off for a few seconds. There is no resistor in that system, BUT, those glow plugs are extremely sensitive to high voltage. If you are using a battery charger or jumping with another vehicle you can pop them real quick depending on state of charge in batterys etc. Any thing over about 14 volts can blow them and as normal charging voltage is usually over that , you should not put glow plugs back on to clean exhaust after starting engine. You should hold them on all the time you are starting and keep them on until clear and that will normally keep charging voltage down as the generator does not put out enough amps to reach regulated voltage with glow plugs on. I have seen guys blow all six real quick with their chargers and jump starting procedures.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
