Re: What should I expect from my A
Posted by gtski on January 28, 2012 at 14:43:22 from (4.131.21.117):
In Reply to: What should I expect from my A posted by Machine249 on January 28, 2012 at 13:35:25:
You have almost doubled your horsepower, so you have to be careful with the rest of the drive line. Plow questions always depend on soil condition and what you really want to accomplish, 80 acres or 80 foot garden? The A is a light tractor for much "heavy" field work hence Culti-Vision. Small tires, light tractor: yes you could pull a 2 bottom little genius but not sure you will be happy with the results.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
