Re: What should I expect from my A
Posted by Brian Dan on January 28, 2012 at 15:34:14 from (71.10.108.51):
In Reply to: What should I expect from my A posted by Machine249 on January 28, 2012 at 13:35:25:
You might have the horse power but do you have the weight? If you do not have enough weight on your tractor you will not be able to pull your plow.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
