Re: What should I expect from my A
Posted by Harold H on January 28, 2012 at 20:54:17 from (12.23.231.187):
In Reply to: What should I expect from my A posted by Machine249 on January 28, 2012 at 13:35:25:
Not related to horsepower, but, since you have the F240 engine, why don't you also install the hydraulic pump from the 240, mount a resovoir and valve, and then you will also have hydraulics on your A.
Harold H
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
