Re: What should I expect from my A
Posted by gene bender on January 28, 2012 at 22:38:28 from (67.55.227.172):
In Reply to: What should I expect from my A posted by Machine249 on January 28, 2012 at 13:35:25:
The 240 ran many more RPMs. The one i had ran pto speed before it was at full RPMs according to the tach. You must also remember the 240 had better tires and wt for traction. You will need good 9.5 with probably two wts per wheel if you are going to do much plowing. Dont go with larger tires as that will cut your power too much as wt is the thing for the B when plowing. The B had very high ratings at the Nebraska tests but had wheel wts and if i remember weighed in at like 3200. I have pulled 2-12 with the B and power is no problem but traction is.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
