Re: H starves for fuel ?
Posted by Janicholson on January 29, 2012 at 07:04:45 from (67.72.98.45):
In Reply to: Re: H starves for fuel ? posted by tuckermac on January 29, 2012 at 06:32:16:
Fuel flow starts with the air getting into the tank vent in the cap, then the inlet to the sediment bowl in the tank, the screen in the bowl, the fuel shutoff on the exit from the bowl, the line, the screen at the carb fitting, the seat in the carb, and the needle/ float system. (I stop there because the engine runs for a minute then starves.) If the filter is for gravity feed it will be OK for now, if for a Motorcycle it might plug easily
Diagnosis:
Put the exit end of the filter into a tin can and turn on the valve. if it flows a pint and a half a minute or more it is OK.
If not try the test before the filter.
If it does flow well, do the same test at the carb fitting, there is a screen in the fitting and it is often catching rust flakes from the line.
If it flows freely and as above, try the same tactic at the bowl drain. If it flows well there, the carb is getting enough, and the issue might be in the internal passages.
If not pull the bowl off of the carb while still on the engine. the bowl must not touch the float either when no fuel is in the carb, or when it is floating. If it touches, it will be unable to float and shut off the fuel correctly, or closed too far and not let enough in.
Put the can under the float and turn on the fuel.
At this point a pint a minute (1/2 liter) is good.
if not, take the needle out and see if it will flow Without a needle as it should. If not pull the seat and clean the passage above the seat.
if so concentrate on the float and its mechanical action with the bowl. The tang of the float to the needle, and the float drop tabs.
Best of luck, Jim
Hold the can under it
