Oil and glazed surfaces will do that. There should be material remaining above the rivets on the bands, if bonded, the bands should be more than 3/32 thick at any location. To remove oil contamination, use brake clean spray to remove external oil, then heat the bands with a propane torch (not oxy!!!) until the oil is baked out, Do not heat radically, just maybe a 3to 4" length moving the torch all the time. When the oil stops coming out, wipe down and rough the surface with 250 grit paper. The seals are removed from the outside, do not take out the carriers without removing the bull gears!! Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
