Farmall Tractors Discussion Board
Re: 560 weight
Posted by Harold H on January 08, 1999 at 17:22:04:
In Reply to: 560 weight posted by gene on January 08, 1999 at 14:44:35:
Gene,
The shipping weight of a Farmall 560 diesel tricycle was 5898 lbs with 6.00-16 front tires and 15.5-38 rear tires. Nebraska test # 699; 59.46 max belt hp, 54.86 max db hp, corrected for sea level: 62.60 max belt hp, 58.67 max db hp. If the tractor has been sitting over a year, assuming it was running when parked, I would not trust the fuel. Diesel fuel grows algi and such and has probably condensed water. I would drain the fuel and put in new filters and fuel. You will then have to blead the fuel system. Be sure you have a good hot battery. Hold the glow plug button till the glow plugs get hot and hit the starter. With luck it will roar to life. DO NOT use ether because the glow plug engine has pre combustion chambers and the use of ether can cause engine damage. After you first do the above and get it running, all furture starts should be easy because with good glow plugs and a good hot battery the 282 is a very good starting engine.
Harold H
Post a Followup
: Re: Re: 560 weight
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
