Re: h starter rebuild pointers.
Posted by Janicholson on January 29, 2012 at 19:33:45 from (67.72.98.45):
In Reply to: h starter rebuild pointers. posted by primerk5 on January 29, 2012 at 18:53:33:
The following will do it:
Take pictures!!!
Clean with Electric motor cleaner spray.
Remove the bushings in the drive housing, and
brush end frame. The blind hole can be difficult,
use a good hacksaw blade cut to a 45* angle to cut
through the bushing. The drive end bushing will
push out with a small socket or square end shaft
that is correct to push on the diameter.
The armature should be true and flat. A lathe is
best. A drill press is next with a sharp flat
file, followed by polishing with 400 grit to
smooth.
The mica insulators between each segment of the
commutator should be undercut. It can be done
with that hacksaw, but is easier with a Dremel and
tiny cutoff saw Make a jig to V the commutator,
and hold the tool in alignment. Cut only 1/32
deep below the copper.
Purchase a new style cushion drive pinion (small
wimpy looking spring, much better design)
Reassemble with moly grease in the bearing pocket
and in the drive end bushing.
Get help (four hands) or use stiff wire to hold
the brushes back while putting the armature into
the brush end frame.
Put on the band and paint it black. Best of luck.
Jim
