Re: h starter rebuild pointers.
Posted by Bob M on January 29, 2012 at 20:26:01 from (67.240.168.45):
In Reply to: Re: h starter rebuild pointers. posted by primerk5 on January 29, 2012 at 19:45:27:
Jim's advice is right on - as usual!
An addition however: Inside the starter frame check carefully the soldered connection between the input stud and the heavy copper conductors. If there's any cracks, looseness, etc. in the soldering take the frame to a starter shop and have the stud resoldered. (Unless you have a BIG honkin' soldering iron it's impossible for the average mechanic to make a good solder joint here.)
Also check the insulating bushing around the stud. If it's cracked or deteriorating now is the time to replace it.
