Re: Slow gears
Posted by DeltaRed on January 30, 2012 at 07:13:02 from (67.6.229.75):
In Reply to: Slow gears posted by Mike Lumley on January 30, 2012 at 06:01:10:
You're running out of power before running out of traction when pulling the sled,right?You need to work on the engine,not the transmission.A member in our club has a JD B with low "Vegatable" Gears.It wont pull much-spins out sooner.you will have to put lots more weight on it,then that same weight will put you in a higher wt.class.Then you will right back where you started....Steve
