Re: German Dielsel 756
Posted by LPGAS ONLY on January 30, 2012 at 10:42:49 from (12.132.38.130):
In Reply to: German Dielsel 756 posted by Mark W. on January 30, 2012 at 10:12:15:
You might have to change the front and rear covers around, but, yes it should work just fine.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
