Re: German Dielsel 756
Posted by MN Scott on January 30, 2012 at 11:32:42 from (98.125.101.119):
In Reply to: German Dielsel 756 posted by Mark W. on January 30, 2012 at 10:12:15:
I put a combine engine in my 756 a couple years ago. You need to swap the rear plate, oil pan, and oil pump from the tractor engine to combine engine. The combine engine's oil pump is internal and the tractor's is external. You need too swap all related parts. Front cover is fine, no swap needed. Really a very simple swap.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
