Re: What do i need to switch from a 360 to a 466?
Posted by andrew hegeman on January 30, 2012 at 15:47:55 from (173.123.220.62):
In Reply to: What do i need to switch from a 360 to a 466? posted by kennell on January 30, 2012 at 13:32:28:
radiator, fan, fan shroud, front cover, fuel tank and support bracket, flywheel, clutch,probably want to go with the tractor manifold on the exhaust side,engine back plate. other random parts along the way
