Re: Problem with 340 IH Utility - Gas
Posted by Janicholson on January 30, 2012 at 19:13:21 from (67.72.98.45):
In Reply to: Problem with 340 IH Utility - Gas posted by John Ratu on January 30, 2012 at 16:15:30:
That kind of leaning in operation can be a sign of an intake manifold leak that widens as it gets to temperature. Use a propane tank with the end nozzle off (pure propane) with a modest flow like it was a small flame if it was together. while it is running (outside) put the propane source near the exterior of the intake manifold at the head and the carb to manifold connection. If it runs faster at any spot, it is likely leaking there.
A second issue to check is the ignition coil. If it is getting so hot you can't touch it when it is doing it, put a new one on it. Jim
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
