Re: Small gas starting tank
Posted by LarryM on January 30, 2012 at 23:37:29 from (76.210.69.201):
In Reply to: Small gas starting tank posted by AL Moyer on January 30, 2012 at 20:49:24:
I have had awesome success with the electolosis process in the link. I will say however that I have a 24VDC 10 AMP battery charger I keep aropund just for this process. I can "cook" a gas tank clean in a couple hours. In fact in two hours the tank will be warm to the touch. Also, I built a PVC tee to place the electrode down in the tank without shorting out. I also use sodium bicarbonate in 50lbs bags from the feed store. There is something about this process that seems to leave the surface less vulnerbale to rusting back up. Kind of like the difference between steel that has been wire wheeled and steel that has been sand blasted.
