Re: Small gas starting tank
Posted by Dave H (MI) on January 31, 2012 at 08:54:33 from (66.87.4.115):
In Reply to: Small gas starting tank posted by AL Moyer on January 30, 2012 at 20:49:24:
I'll go with some variation of Jim's method as the easiest on the tank. If you use an acid, the first rinse is with water and after that baking soda in water to bring the PH back up to a more neutral number. You best coat it PDQ with oil or similar or it will rust up on you in short order.
