Re: Plastigage use
Posted by rustyfarmall on January 31, 2012 at 11:23:33 from (216.248.71.224):
In Reply to: Plastigage use posted by rustyfarmall on January 31, 2012 at 08:18:27:
Really is no good way to check the cam bearings other than pull the cam out and eyeball the bearings. If they look worn, replace them.
No need to worry about it if the engine was carrying good oil pressure and running good before you tore it down.
