Re: Super C was running-not now
Posted by El Toro on January 31, 2012 at 18:14:44 from (108.3.225.57):
In Reply to: Super C was running-not now posted by MarkinMo2 on January 31, 2012 at 16:22:02:
You could pull a sparkplug and see if it's black
or wet. Could be as mentioned being flooded.
If one is wet I would pull all of them and let them dry. If you have air pressure I would blow some air on them. Then reinstall them and give it a little snort of carb cleaner to see if the engine fires. You probably will need to rebuild that carburetor if gas keeps dripping. Check that float to make sure it isn't filled with gas, you can do that by shaking it. That float seat may have dirt in it keeping the float from shutting off the gas. Hal
