Re: 1086 Engine Labors When Steering
Posted by pete 23 on February 01, 2012 at 10:19:42 from (74.32.238.142):
In Reply to: 1086 Engine Labors When Steering posted by TMatt on February 01, 2012 at 04:48:43:
If turning the wheel slightly stops the laboring, the problem is in the hand pump. With engine shut off, you should be able to feel the free movement in the hand pump nice and free and equal in both directions and it should return to center when you let go of it. That free movement is the torsion bar windup moving the internal spool. Different hand pumps have different torsion bars with lighter ones making for easier steering but they also could make it more difficult for the valve to return to neutral with the less tension from torsion bar.
