There is no provision for adjusting the vertical end play of the upper bolster shaft. The weight of the tractor keeps it in place. If the noise is really a problem you may want to consider slowing down a bit for the rough spots.
The end play can be controlled by installing washers between the steering gear and the upper bolster. You must maintain a little end play because the gear has a taper fit on the upper bolster shaft which must get tight before all the end play is gone while tightening the retaining nut.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
