Re: Rude awakening with my 1206
Posted by Owen Aaland on February 01, 2012 at 13:14:49 from (216.47.35.22):
In Reply to: Rude awakening with my 1206 posted by LarryT on February 01, 2012 at 11:50:25:
The most likely cause for you problem is hardening of the O-ring seal between the center section and the rear frame.
The oil passage between the filter and the MCV pump goes above the normal oil level where the two housings join together. With age the O-ring will harden and take a set so that it will not seal properly. Air enters the suction side of the pump and as the pump starts to get worn it no longer is as efficient at pumping air as a new one. Adding enough oil to ensure that this O-ring is below the oil level will keep air from entering the suction side of the pump and the symptoms will disappear.
