T-20 parts tractor.
Posted by Dandy Dave on February 02, 2012 at 08:11:55 from (68.237.142.133):
I have an Internatioal T-20 Parts crawler here if anyone needs anything off of it. No mag, No carburetor. No manifold. Track pins are worn, but it does roll. Radiator Core is bad as it looks like the fan went threw it at one time. Block is cracked and motor is stuck. On the up side, the fuel tank looks good and is clean inside and the trans turns. Tell me what you may need and I will look. I would also consider trading some of the parts for a pair of hood sides if anyone has a set to trade. The crawler is located in Craryville NY 12521. Give me a shout before it goes for junk. (518) 325-7610. Leave a message and I will get back to you if I"m not around. Thanks, Dave!
