Posted by Aces on February 02, 2012 at 08:26:00 from (66.172.223.13):
In Reply to: Farmall Bolts posted by schultz on February 02, 2012 at 05:09:17:
Schultz! If you go back to the H,m through the 450's you will see the IH bolts with the dot in the center on side rails and clutch housing to rear end. Had all kinds of trouble with them coming loose. Then the 460 560's had grade 8 with stare washers, that was better. 706 806 656 had grade 8 and no washers. No problem coming loose. So I used grade 8 and no lock washer on all tractors after the 06,56 came out. Just use a long wrench a tighten them up goood. I will not use a lock washer on anything,, waste of time and money.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
