Posted by rustred on February 02, 2012 at 09:43:13 from (74.200.18.156):
In Reply to: 460 running too rich posted by NolanJae on February 02, 2012 at 08:52:24:
float level is 1 5/16. the main fuel adjusting screw should be 5 turns out for heavy pulling. but for idling around try 2 1/2 - 3 turns out. turn the idle mixture either way to get a smooth idle and adjust throttle screw for slow idle of 450rpm. make sure points and timing is set before carb adjustment. also get it under load for a while to clean it self up.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
