Re: Old A model
Posted by BEL@ IN on February 02, 2012 at 10:45:39 from (173.171.156.105):
In Reply to: Old A model posted by BoonvilleKid on February 02, 2012 at 09:57:20:
First it sounds like the throttle is stuck open or the carb idle screw in too far. Engine should idle nice and slow. As for the switch, on the side of the mag there is a single screw with some plastic (micarda) around it. Ground this screw to frame and it will stop. Good luck.
