Posted by rustyfarmall on February 02, 2012 at 11:01:38 from (216.248.71.224):
In Reply to: Farmall Bolts posted by AG in IN on February 02, 2012 at 05:09:17:
Mike, I like your philosophy. It's your tractor and you painted it as you wanted.
I also leave the new bolts unpainted. If the tractor is kept inside, out of the weather, it'll be many years before they start to show any signs of rust, and when they do, you can paint 'em then.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
