Re: Farmall C / Super C
Posted by Larry on September 10, 2000 at 04:08:52 from (208.197.116.187):
In Reply to: Farmall C / Super C posted by parker on September 07, 2000 at 16:28:12:
The Super C has a larger engine(+1/8 bore), disc brakes which can't be put on a C without changing the whole transmission/diff case.The internals of the transmission are the same, just the housing is externally different(brake mounting). Super C chassis sn's begin with FC-100,001 and engine sn's begin with FCM-100,001. The super was supplied with a 18 in steering wheel(larger than the c) and a redesigned rear steering shaft bearing along with a few other changes mainly for creature comforts and added durability. I,ve got one of each, hope this helps....
Post A Followup
: Re: Re: Farmall C / Super C
