Re: Starting problem
Posted by soundguy on February 02, 2012 at 17:15:53 from (107.41.212.242):
In Reply to: Starting problem posted by 53 super H on February 02, 2012 at 16:56:31:
if I read you correctly, while cranking it won't fire but as soon as you release the starter it does?
if that is correct.. then I will asusme you are battery ignition, and you are getting low power to the coil and points..
when that huge starter load eases up, she is still spinning and thus fires.
check battery to make sure it is good.. make sure cables and ends are good and correct size. clean all grounds and terminal ends.
check all connections at ignition switch and coil / any resistors / at the dizzy.
once all cleaned up.. re check.
if starter drags it will eat power.. IE.. may need bushings.
if that is not it, try jumping out ignition switch.. might be bad contacts.
also may try swapping in a known good coil if you are usig an older one. older non oil potted coils don't last like the new ones do many times...
post back
( ps.. i bet a donor battery hooked tot he coil / ground, makes her fire right over when you hit the start button? )
soundguy
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
